PaulRC
#1 Posted : Sunday, December 30, 2007 8:00:27 PM(UTC)
PaulRC
I have read dozens of posts here and cannot solve my problem.Washer fills with water but does not agitate, spin nor drain. When I try to cycle it to a spin and drain there is a loud clank but no other action except the timer counting down.
I ran through the diagnostics for the panel, motor and cap all are within specs. Also removed pump (is fine) motor (the coupling is fine). I can spin the coupling at the transmission clockwise and the tub turns but I cannot turn the agitator bottom. What should I do next?
Thanks,
Paul
okbobcats
#2 Posted : Monday, December 31, 2007 4:42:26 AM(UTC)
okbobcats
turn the shaft on the transmission counter clock wise to see if it turns.
PaulRC
#3 Posted : Monday, December 31, 2007 5:58:50 AM(UTC)
PaulRC
Yes, it does turn the agitator.
PaulRC
#4 Posted : Monday, December 31, 2007 6:56:29 AM(UTC)
PaulRC
OK. AS this thing is driving me crazy I decided to hookup the motor outside of the machine and try and cycle the machine so the motor would spin. When I put it on the drain/spin cycle I hear the same loud clunk when I push the lid switch (which I also removed from the cabinet) but the motor does not spin! I checked the capacitor with an OHM meter and it seems fine.
Any thought please.
Paul
okbobcats
#5 Posted : Monday, December 31, 2007 7:44:48 AM(UTC)
okbobcats
Does the motor turn over easy by hand? seems to me that your motor is locking up. If you hear the clunk with the motor off the machine.
PaulRC
#6 Posted : Monday, December 31, 2007 9:05:04 AM(UTC)
PaulRC
I went back and started from the beginning. After redoing the panel diagnostics and running tests on the agitation cycles as per the troubleshooting guide I discover a 0 voltage reading on the panel P7 and P9 pins so apparently the main circuit board is bad. I ahould have known because the dryer panel also went bad do to a faulty wall socket.
Regards,
Paul
SChambers
#7 Posted : Thursday, November 13, 2008 11:37:44 AM(UTC)
SChambers
Hi - I have just experienced the exact same problem on the same washer - no agitate, spin or drain, and a clunk, like it wants to work. Paul (or anyone else), how did you fix yours - was this a board failure, or was it maybe a gearbox problem? If it's the board, then I might go ahead and get a new board.
Any answers would be greatly appreciated. Thank you.
Steve, Orange County, CA
Email SSS.Chambers@gmail.com
v2k04
#8 Posted : Thursday, November 13, 2008 12:08:15 PM(UTC)
v2k04
nevermind...........
SChambers
#9 Posted : Thursday, November 13, 2008 12:24:12 PM(UTC)
SChambers
Yes, it's a Catalyst washer. The clunk sound I mentioned is the normal, rather loud sound that the washer makes when changing functions, like agitate stop, spin start etc. Maybe the solenoid?
