juliog
#1 Posted : Wednesday, January 4, 2012 6:20:47 AM(UTC)
juliog
The dryer does heat up but for some reason the lint catcher is not filling up with lint as usual. I took the front off and found lots of lint around the metal housing of the heating element and in the trans duct and blower housing. I cleaned/vaccumed it all out but still no luck. Also the lint catcher is humid and it hasn't been in the past. Any thoughts?
#2 Posted : Friday, January 6, 2012 5:07:02 AM(UTC)
Unplug the unit and disconnect it from the vent system.
Now try a run.
If it now dries OK odds are the vent system needs checking/cleaning.
Be sure to check that the louvers on the outside of the house open correctly.
If you do not want any lint in the house.
Take a pair of pantyhose.
Put one leg into the other and then attach this to the dryer's vent.
Leave enough room so the pantyhose can balloon out like a windsock.
Both the above will let you check the temperature and the air flow.
