theodor
#1 Posted : Monday, July 6, 2009 2:50:51 PM(UTC)
theodor
[FONT='Arial','sans-serif']What lubricant do you recommend or how do you put this part on so that it does not either wear away, stop machine. Is there anything that can be put on the rubber seal and washer stem, like a lubricant? Your help would be greatly appreciated. [/FONT]
[FONT='Arial','sans-serif'] [/FONT]
[FONT='Arial','sans-serif']Mounting stem repair kit[/FONT][FONT='Arial','sans-serif'] - Maytag washer stem and seal kit, comes with hub assembly, seal and spanner nut. AP244279 should also be replaced at the same time. Part Number: AP4390013 made by WPL[/FONT]
applianceman
#2 Posted : Monday, July 6, 2009 3:15:46 PM(UTC)
applianceman
Do not use any lubricant to replace this part except for some soap to help install the part. this page will help Maytag Tub Seal Replacement
