JXNjack
#1 Posted : Monday, July 6, 2009 9:50:22 AM(UTC)
JXNjack
The turntable in this combo microwave/convection oven stopped revolving. I didn't notice any early signs of a problem (like sporadic or start-stop revolutions) -- it just occurred suddenly.
I've been looking through other posts here to try and diagnose the issue. There's nothing obviously wrong that I can see with the coupler drives the glass turntable itself. I haven't tried pulling the coupler off to check for cracks, though -- the coupler doesn't easily lift off the base and I didn't want to force it.
Is there a way I can eliminate other potential causes before I try replacing the turntable motor?
Thanks, Jack
#2 Posted : Monday, July 6, 2009 8:37:55 PM(UTC)
Remove the bottom panel and the two screws holding the turntable motor. Now you can easy remove the coupler for inspection.
Here are the breakdown diagrams and Replacement parts for GE JVM1490WD003 | AppliancePartsPros.com
