sofedup
#1 Posted : Monday, January 2, 2012 8:18:51 AM(UTC)
sofedup
I have exactly the same problem as everyone else with my <3yr old Oasis washer. I have followed and tried suggestions from this site and have spent $206 for the elctronic board (plus laundromat fees) trying to fix my washer. I had the part professionally installed and the test after installation seemed good. Next day, I tried to do laundry only to have different error codes "oL", then whatever.
Although my machine is a couple of numbers out of the recall, I've read posts where others were included and fixed free of charge. I've tried them all. Nothing.
I've given up and accepted that "they don't make things like they used to" and have tried everything that should've worked. Suggestions?
Thanks Kim
sidfink43
#2 Posted : Tuesday, January 3, 2012 4:29:16 PM(UTC)
sidfink43
This is an extremely difficult machine to diagnose. It sounds like your board was the problem, and that something is causing it to malfunction which is why it failed again.
It may be a problem in the wiring, a problem with the connections or sometehing else, butat this point I can only suggest a professional tech visit or replacement, neither of which are particularly inexpensive choices.
Sorry not to be of more help, that's the nature of this model.
