bishop
#1 Posted : Sunday, July 5, 2009 1:42:21 PM(UTC)
bishop
My Whirlpool dryer (LGR4634EQ1) recently stopped heating. The igniter begins to glow when the dryer starts, but within seconds it stops glowing again. I have already replaced the fuse, and that did not fix the problem. Any other suggestions would be greatly appreciated!
sidfink43
#2 Posted : Tuesday, July 7, 2009 12:15:55 PM(UTC)
sidfink43
Hi Bishop
I am not a gas man so I cannot give you specific ideas, but if you look at the postings on gas dryer on this Forum almost all recommend changing the coils. If that is not the problem you will see other suggestions.
You should first check out all of the thermostats for continuity.
Good luck, let us know if you need more info.
Electric Whirlpool Dryer - no Heat! (Dryer Repair)
by willow5000 2/5/2013 10:51:32 AM(UTC)
Whirlpool Dryer - No heat, Timer Does Not Advance (Dryer Repair)
by katielove22 10/21/2012 12:26:02 PM(UTC)
Whirlpool Dryer - no heat (Dryer Repair)
by willrw 11/10/2009 6:26:46 AM(UTC)
Whirlpool Dryer - No heat (Washer Repair)
by lpaw 4/15/2009 4:03:29 AM(UTC)
Whirlpool dryer - no heat (Dryer Repair)
by verruckt 4/22/2008 6:40:50 PM(UTC)
Whirlpool Dryer - No heat (Dryer Repair)
by Warren 8/14/2007 2:30:36 PM(UTC)
