This problem started about a 2 weeks ago. Water drips over icemaker and runs down the front edge of freezer. Help!!
If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
If it continuously drips, replace the water inlet valve on the back where the house water supply comes in.
It seems to be working. Thank you for the heads up. Saved a repair bill.
