everything work fine but the noise so loud ( seam like metal touch metal ) when drum spinning. Please help. Thanks
The front of your dryer drum rides on some pads. When these pads wear out the metal drum rides on the metal frame giving you that metal on metal sound. Here is the service manual for your dryer. It should help you take it apart and replace the pads. http://appliancejunk.com...ownloads;sa=view;down=67The pads are #30 in this diagram. ![UserPostedImage](http://www.appliancepartspros.com/sect/4/b/a/4bad6typyp.gif)
Thank you very much for your help to fix my dryer problem. Happy New Year!!!
Hoan.
