lavadora
#1 Posted : Friday, July 3, 2009 4:06:51 PM(UTC)
lavadora
My washer does not fill up. I was doing a load and on the rinse it just kept the water going but it never filled the hose is O.K. because I do not have any water around the washer. Water is running into the machine O.K.. Is the washer repairable?
Drags1998
#2 Posted : Friday, July 3, 2009 4:52:03 PM(UTC)
Drags1998
Sounds like it is syphoning, pull the drain hose up out of the drain or make sure that the hose goes higher than the water level in the machine. That should take care of your problem!!!:)
maytag washer will not hold water in tank (Washer Repair)
by rbhayden 4/18/2008 9:05:01 AM(UTC)
