jdbrockman
#1 Posted : Friday, July 3, 2009 11:59:16 AM(UTC)
jdbrockman
How do I remove the ice maker? I have taken the bottom screw out of the ice ben but it hits the ice maker when I try to remove it. I knew it looked to easy.
woodchuckie
#2 Posted : Friday, July 3, 2009 2:25:31 PM(UTC)
woodchuckie
The ice maker hangs on the wall with three screws. two at the top and one at the bottom. Just loosen these screws and the ice maker will lift off the bracket and you can then reach the wiring harness to unplug it.
jdbrockman
#3 Posted : Saturday, July 4, 2009 12:06:25 PM(UTC)
jdbrockman
What I really needed to know was how to take out the ice bin. Does the ice make need to come out first? I tried removing the screw from the bottom of the bin an then lift it up off the pegs. The bin hits the ice maker.
How do I remove the Ice Maker? (Refrigerator & Freezer Repair)
by Siri 6/1/2009 11:16:40 AM(UTC)
