Just moved intoan older home with a real clean looking Tappan range/oven. It is a manual unit with knobs for ON Off and temp control. When set to 325, oven runs up to 450-475. I checked with fluke temp meter and probe. I can't seem to find any info on the web on this model, Any help would be appreciated. I looked at the temp control and it has part number DT1-40-42. Joe
Thanks Dan, It is a WCW3. The link you sent showed the Thermostat at 265.86, so I guess I will opt for the 3.25 oven thermometer. Thanks , Joe
Quote:Thermostat at $265.86, so I guess I will opt for the $3.25 oven thermometer. Yes, the thermostat used on your model is towards the upper scale of what they can go for. :rolleyes:  I would * strongly* suggest you do not let the appliance out of your site while using the oven because if the thermostat is out that much, there may be a very good chance it will eventually fail totally possibly resulting in uncontrollable heating in which case [COLOR="Red"]your oven could pose a very real fire hazard![/COLOR] :eek: JMO Dan O. www.Appliance411.com The Appliance Information Site=D~~~~~~
