I have a U-Line Small Icemaker and I cannot seem to get the Compresser to turn on. I have narrowed my problem down to the Relay or the Overload Protector on the compresser. How do I test the Overload Protector - It pushes on the positive lead on the compresser and there is a wire connecting the power to the other side. When I use a Multimeter I do not get continuity between the two points...should I? Also how do I test the relay? It has one nuetral and the other two leads go to the Capacitor.
Thanks Tom
