Dishwasher, wouldn't turn on, checked it out, a circuit breaker had tripped, so checked that out, and found thermostat bracket had come loose and shorted it out. Reattached bracket ran dishwasher, worked but heater did not shut off. Replaced thermostat, heater still will not shut off. Problem with circuit board now?
Check if the heater is not shorted to ground.
The model number you posted does not come up. Verify and repost it.
