BGarland
#1 Posted : Monday, December 26, 2011 10:26:36 AM(UTC)
BGarland
GE GSH25JFTACC - Refrigerator-Freezer defrosts too much, icein bin melts and clumps together, frost and moisture forms on all items infreezer, frozen water drips form on edges of shelves. Have already replaced bin and some auger parts due to ice re-freezing and putting strain on plastic parts to dispense. I have had GE certified repairman look at andhe wants to blame too much air flow into freezer. That is not the problem - the gaskets are allfine, the ice dispenser in door is sealed well. I read something on a troubleshooting boardabout the thermistors being the problem. I don't want to keep paying repairmen to come and guess with hit andmiss solutions.
#2 Posted : Tuesday, December 27, 2011 3:18:59 AM(UTC)
If the freezer fan still runs when everything is melting, pull the motherboard cover off in the back and check the board for bad solder joints behind the big power relay. You can order the board here AP4436216
