Todd K.
#1 Posted : Saturday, December 24, 2011 9:04:10 PM(UTC)
Todd K.
I had the flickering light symptoms. These forums pointed me to the PCB assembly. I thought I would have a look at the old one first before ordering a new one. The new ones are expensive. I found a very obvious loose solder joint on one of the big blue relays. Re-soldered it and all is well. I did not even have to take the board all the way out to do it. Just removed one 1/4" hex head screw, all the connecters to that sub-board, released the four tabs and flipped it over.
Hope this helps
Todd K.
ApplianceJunk
#2 Posted : Saturday, December 24, 2011 9:35:38 PM(UTC)
ApplianceJunk
Good find!
It's always worth looking over any board for loose solder connections before replacing it.
Thanks for posting.
