gonzo
#1 Posted : Friday, December 28, 2007 12:08:34 PM(UTC)
gonzo
For a while now our washer has been emitting a rapid, moderately loud tapping noise when in the spin cycle. It seems the drum has a lot of lateral travel and the hose on the side of the drum may be hitting the side of the cabinet. Also a while ago I changed out the water pressure switch as full loads would cause an overflow in water. Again it may be that the lateral movement of the drum is so great it is causing so much motion that water is sloshing out. What could be causing this? Do the drum retaining springs eventually get weak, go bad? Bearings?
thanks in advance for your response
gonzo
#2 Posted : Friday, December 28, 2007 12:15:03 PM(UTC)
The first thing I would do is remove the front panel and inspect all suspension and moving parts.
Post your findings.
- Here are the break down diagrams for the Amana washer Model LW8253W
Good luck and Happy New year.
Whirlpool washing machine drain/spin noise (Washer Repair)
by wlakeberry84 6/24/2014 8:25:04 PM(UTC)
Spin Noise and Vibration (Washer Repair)
by juanrodman 1/26/2014 8:03:31 PM(UTC)
Samsung front load spin noise (Dishwasher Repair)
by mastarj 6/14/2012 6:21:50 PM(UTC)
Maytag Centennial (Top Load) Spin Noise (Washer Repair)
by headusher 6/1/2012 9:42:10 AM(UTC)
spin noise at start of cycle (Washer Repair)
by justfixin 5/28/2012 2:45:43 PM(UTC)
by control 5/24/2012 10:52:53 AM(UTC)
Spin noise / out of balance (Washer Repair)
by 3080 5/7/2012 3:18:26 PM(UTC)
spin noise/tool (Washer Repair)
by bobalou07 2/9/2012 1:05:41 PM(UTC)
Spin noise Sounds Evil (Washer Repair)
by xcyclerepair 2/12/2010 3:51:06 AM(UTC)
GE washer spin noise (Washer Repair)
by bob&sherry 3/13/2009 8:29:50 AM(UTC)
