ahouse1
#1 Posted : Tuesday, June 30, 2009 10:47:48 AM(UTC)
ahouse1
Hi all~
Single mom with backed up wet laundry.....
Dryer not working at all. Will not start. Have the back taken off but not sure what I'm looking for. Any help or suggestions will be greatly appreciated. :(
#2 Posted : Tuesday, June 30, 2009 5:43:04 PM(UTC)
The first thing I would do is check for 120 VAC to the dryer. You can plug it in a different outlet, using an extension cord.
If there is nothing wrong then check the door switch and its actuator (#9 & #10 on the diagram)
Post the results.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL KGYE660WWH0 | AppliancePartsPros.com
