Randog
#1 Posted : Tuesday, June 30, 2009 9:52:53 AM(UTC)
Randog
Hello all,
I am hoping I may get some direction on how to proceed.
I have a Bosch SMU4056; and until recently, it has been a great performer.
The washer was working great and then one day it just stopped in the middle of the wash cycle.
If I cycle through the different cycles it does nothing. There is no sound, no pump noise. Nothing.
I used a shopvac to get the water out of the unit.
I am not sure how to proceed to troubleshoot the unit. I have not been able to find much of anything on the internet for test procedures.
Any direction and help woul dbe greatly appreciated.
Thank you in advance,
Randy
#2 Posted : Tuesday, June 30, 2009 5:09:03 PM(UTC)
Hi Randy,
The first thing I would do is check for 120 VAC to the dishwasher.
Remove the toe panel and check the power cord connection to the dishwasher for burned wires and/or lose connections.
Remove the outer door panel and check all wires inside the door.
Check the "on-off" and the door switches.
Here are the breakdown diagrams and Replacement parts for BOSCH SMU4056 UC/09 (FD 7307-7902) | AppliancePartsPros.com
Randog
#3 Posted : Tuesday, June 30, 2009 6:00:20 PM(UTC)
Randog
I will verify the voltage when I get home tonight. I had the thing apart last night but had no clue where to check, and what to check.
I'll start with the voltage and wires.
Thank you for your help!
#4 Posted : Tuesday, June 30, 2009 6:03:08 PM(UTC)
Randog
#5 Posted : Tuesday, June 30, 2009 9:26:42 PM(UTC)
Randog
I checked the incoming line and the power coming is 110v; so that is good.
I checked the voltage at the lines coming in to the Selector Switch Assembly and the voltage is still good. From there, I am not too sure what voltages should be - and where.
The odd thing, and I don't know if this is norl - I cannot remember - is that then the door is opened and the on/off switch is depressed the light comes on (for behind the on/off switch) but once the door is closed - the light goes out. Very odd.
I noticed that the motor for the timer unit is not turning. From what I can gather it is not getting power (?)
I did not get a chance to yank the unit out from under the counter top. That will be tomorrow.
The I guess I can check the other components.
Dishwasher unresponsive except cancel (Dishwasher Repair)
by crazymech 10/20/2009 6:53:56 AM(UTC)
