I want to omit the water filter,do I need a bypass plug for this model?
Originally Posted by: jomicasa ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) I want to omit the water filter,do I need a bypass plug for this model? Jomicasa. No, you do not need a "bypass" plug for your water filter system, but you do need to reinstall the filter housing cap. " Using the Dispenser Without the Water Filter
You can run the dispenser without a water filter. Your water will not be filtered.
1. Remove the water filter.
2. Slide the cap off the end of the filter and replace the cap in the base grille.
IMPORTANT: Do not discard the cap. It is part of your refrigerator. Keep the cap to use with the replacement filter. 3. Rotate the cap until it is securely in position. " Thanks and Good Luck, :) :) :)
Originally Posted by: jomicasa ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) got it ,thank you! Jomicasa, Anything else, just drop us a line. You're welcome . Thanks Again, :) :) :)
Originally Posted by: jomicasa ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) I want to omit the water filter,do I need a bypass plug for this model? Thank You. Happy Holiday`s
Originally Posted by: jomicasa ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Thank You. Happy Holiday`s You're welcome, We hope you have a Happy New Year, as well. :D :D :D
