The dishwasher runs a full cycle fine. Seems to drain as it should. But, the pump turns off and on intermitantly. What is causing this and how do I fix it.
Quote:...the pump turns off and on intermitantly... If the wash pump does it during a cycle - that's the way how it's designed and it's normal. Gene.
