Kenmore start/stop device relay, part # 2220475/8201786
Hi - I removed the start/stop device relay and shook it, and there is definitely lots of loose debris inside. You can hear the compressor clicking on, and then off 10-20 seconds later. The compressor is hot to the touch, so my question is: how long do I have to replace the relay? If it takes me 2-4 days to get the part, is that going to cause further issues (blowing the compressor, etc)?
Thanks for your help!!
mike
[FONT=Times New Roman][SIZE=3][COLOR=#000000]I would suggest unplugging the refrigerator until you get the part. It is not going to cool anyway so unplug it. [/COLOR][/SIZE][/FONT]Appliance Repair Guide For All Major Home Appliances
Thanks applianceman! The fridge is cooling, has been for the last week or so until I figured out what the problem is. So am I possibly damaging the compressor then (yikes!). Thanks!!
mike
[SIZE=3][COLOR=#000000][FONT=Times New Roman]If the start relay is bad, neither the fresh food section nor the freezer will work. From your description I do believe the start relay is bad and it could possibly damage the compressor from overheating so much. [/FONT][/COLOR][/SIZE]
The compressor is hot to the touch, but I have left the backing off and pulled the fridge out to get some extra ventilation. The compressor is now staying on. The relay will be here in 2 days, guess I should just unplug it and toss the food then? Thanks again.
mike
I had the click and shut down on my refrigerator. Research on the web says relay is bad. Looking at parts I could not see a matching part for sale on line. Called Sears. Guy put in relay in 5 minutes. Replacement parts (two of them) replaced old defective parts that burn up. old part was black and held on with a clip and had a black ear sticking off it. New parts much smaller. One white with two slide tabs one small cube like.
$270.00 Instead of buying part youself. You do the math. Blue Indian techumsah compressor tested fine. warranty for fridge for 1 year came with service. Guy put the cover back on before I could take picture of replacement wiring. Sorry. good luck
Repair guy says 4 out of 10 calls needed this relay. Class action? 6 year old
Thanks for relaying your experience, very helpful!
mike
Wow! Talk about timing… Mine went bad TODAY. Whirlpool, but same part. Wife called me at work saying something electrical smelled like it was burning. Come home to find fridge clicking on thermal overload every few minutes. Thought it was the cap, but turns out the motor start relay housing (PN2220475) nearly burned. It rattled, and when I opened it, the inside was black and melted. Now to find this part for cheap and fast. Has anyone found this part? Is it something a local parts store might have (not trying to cut out buying from here, but I’d love to save the mild, eggs and lunch meats).
I gutted the relay base - removing the shards of the resistor that was previously inside. I made a jumper with a momentary push-button which, when pushed, will short the start coil with the run coil (via the cap). It worked just fine to start the compressor and it’s running now. As soon as the compressor shuts off, though, it will not restart on its own. For now, I’ve set the temp to the coldest setting, which will buy me some time to find the part locally tomorrow - or order it from here if I can’t find it.
I’ve uploaded a layman’s schematic of the jumper location. This is temporary and will only get the compressor started if held as the compressor tries to start. DO NOT DO THIS IF YOU DON’T UNDERSTAND THE CONCEPT. If you jumper this permanently, you’ll fry the cap, and probably cause a fire.
fridge jumper.jpg (33.1 KB)
try partsdepotonline.com for this part, ships in 2-4 days though…
mike
Ok so I posted earlier that Sears tech replaced relay. Fridge worked fine.
This repair lasted five days!
We lost another refrigerator full of food.
Service tech rescheduled under warranty. First appointment 4 days out. On that day appointment was from 8-5. about 2:00 I decided to call and see where tech was or if he was still coming. Routed though India or where ever and 20 minute computer phone loop I got a human who said tech would call me. 1 hour later tech called(my cell phone, number given to call) and was at the wrong address. Another house I own but not the one that: Was on my service agreement and that the previous tech had serviced fridg. He said he had one more appointment near that area and then would be over. 1 hour later he called again and said the main office told him even tho he was 15 min. to my location that that would have to be handled by a different tech! After several more calls phone loops though texas, arizona and god knows where else and being told someone was on the way. At 5:00 I called again and they stated the tech called and no one answered. I discoved they called my office line and left a message, not the cell number given and which had already been called twice! Now they said there is nothing they can do but reschedule… next appointment 4 more days out! By the way for the food loss you get another 800 number to start that process. I did curse too much at the end of this 12 hour ordeal. The next day I was at the Sears parts warehouse getting parts for another repair and mentioned what had happened. The guy went in the back room and came back and said someone will be out Today July 26. So now am again at home waiting for the Tech. Will update after anyone ever gets here!
[quote=mcs11;103134]try partsdepotonline.com for this part, ships in 2-4 days though…
mike[/quote]
I ordered the relay assembly from a seller on EBY (of all places) on Thursday (July 2th) and I had it in my had by Monday - regular mail. They were in my state, and it was only $15 w/shipping. Fridge has run like a top since then. Of course, we weren’t certain this would solve the problem, and with the anticipated delay for the part, we opted to buy a new fridge. LG this time. $2500 later, we have a really nice shiny fridge in the kitchen, and a perfectly functioning Whirlpool in the garage. To be honest, the LG (4 door) is lacking in many ways and I have considerable buyer’s remorse. Not the right thread so I’ll skip the details.
I posted in my last e-mail I was given a next day appointment 8-5.
I waited patiently for the Tech. I heard my office phone ring at 4:53! It was the Tech. Still after many discusions they call the wrong number! Luckily I caught the phone however and the Tech came at about 6:10. He plugged in unit immediately began to replace BAD COMPRESSOR. YES the TECHUMSAH with blue Indian was the problem. 1 hour later up and running after another 11 hour wait for me. Working fine today. Now to file loss of food report…
Dear Zook11,
I am sorry to hear about the trouble you have experienced with Sears repair service. My name is David and I work for the Sears Cares Team. We would like to speak to regarding this experience. If you can contact us at [email removed] so we can further discuss your concerns. Please include your screen name (Zook11) in your email so we can reference to your case.
Thank you,
David V.
Senior Case Manager
[quote=erkme73;103126]I gutted the relay base - removing the shards of the resistor that was previously inside. I made a jumper with a momentary push-button which, when pushed, will short the start coil with the run coil (via the cap). It worked just fine to start the compressor and it’s running now. As soon as the compressor shuts off, though, it will not restart on its own. For now, I’ve set the temp to the coldest setting, which will buy me some time to find the part locally tomorrow - or order it from here if I can’t find it.
I’ve uploaded a layman’s schematic of the jumper location. This is temporary and will only get the compressor started if held as the compressor tries to start. DO NOT DO THIS IF YOU DON’T UNDERSTAND THE CONCEPT. If you jumper this permanently, you’ll fry the cap, and probably cause a fire.[/quote]
Thanks this worked great get me threw the weekend. Also a good test to test everything else to see if it all works. Now all I have to do is go and get the part monday thank you
@Rob:
Glad to see it worked. My fridge hasn’t skipped a beat since the July '09 incident. Weird how these things always seem to go bad going into the weekend.
Tried the jumper but it wouldn’t work. The overload protector was too far gone and kept dropping out. Otherwise it would have worked.
Bought the parts at a Sears parts store. I called their parts online. They would have expedited the part to me next day at no additional charge if I called before 11 am central time. It was quicker to drive the 25 miles to the store. The part at Sears was $62.82 plus tax, but for that I got two Start-Dev parts with overload protectors and two more overload protectors. I’m set for a while and it’s working just fine.
