Used washer and had a suds alert reset and started to wash again some water came in the machine and then stopped sets there and counts time down reset and it would not open door nor work finally got an f error and the machine allowed me to stop and open door tired again and same results what should i check for?
Probably a bad door switch. Download the Whirlpool job aid located in the general talk section
