wildhare
#1 Posted : Monday, June 29, 2009 7:05:57 AM(UTC)
wildhare
My Whirlpool Portable (Free-Standing )Dishwasher
is clogging and will not drain.
I need some help in clearing the clog
and a diagram to help me figure out
where I should be looking.
The Whirlpool owners manual is not very helpful.
Thanks.
#2 Posted : Monday, June 29, 2009 10:40:00 AM(UTC)
Disconnect the drain hose from the check valve (#15 on the diagram), unscrew the check valve and check it inside.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL DP920PFGQ4 | AppliancePartsPros.com
wildhare
#3 Posted : Monday, June 29, 2009 10:48:10 AM(UTC)
wildhare
Thank you very much for the help
and I do appreciate a starting point
on where to look..
I will let you know what happens.
wildhare
#4 Posted : Monday, June 29, 2009 11:58:20 AM(UTC)
wildhare
Disconnected the drain hose and check the valve
and it is draining and not clogged anymore.
With grateful thanks and appreciation
for all the help!
#5 Posted : Monday, June 29, 2009 7:51:09 PM(UTC)
You are welcome. I'm glad it was that simple.
