lvig
#1 Posted : Monday, June 29, 2009 5:42:44 AM(UTC)
lvig
the refrigerator isn't cooling but fezzer working ok. I read other similiar issues and heard it may be in the defrost heater or control. Is that something that should be covered under limited warranty of "cabinet liner and sealed system"? When I called in for a service call she said if it's not exactly one of those parts I will be required to pay for the service call and parts. They list compressor, condensor, evaporator, dryer and tubing.
Thanks!
woodchuckie
#2 Posted : Monday, June 29, 2009 7:25:04 AM(UTC)
woodchuckie
It's not part of the parts you listed for the sealed system. You'll have to ask them what parts are part of what they call the liner parts.
lvig
#3 Posted : Monday, June 29, 2009 7:30:46 AM(UTC)
lvig
Well I just looked at it and the readings on the temp display are back to normal. It seems it's getting cooler again but I don't hear anything like a fan. I cancelled the service repair call since. Can you tell me what to look at to make sure it's ok?
woodchuckie
#4 Posted : Monday, June 29, 2009 8:16:15 AM(UTC)
woodchuckie
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's open.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
agutshall
#5 Posted: : Monday, June 29, 2009 11:05:25 AM(UTC)
agutshall
location fo flap behind refig temp control
agutshall
#6 Posted : Monday, June 29, 2009 11:08:47 AM(UTC)
agutshall
location of flap adjustment with the temp control
woodchuckie
#7 Posted : Monday, June 29, 2009 3:22:29 PM(UTC)
woodchuckie
That's part 115 on diagram 2. >Replacement parts for FRG FRS6L7EES1 | AppliancePartsPros.com
Guest (7)
Amana Refrigerator not cooling, freezer working (Refrigerator & Freezer Repair)
by sordna 8/1/2009 6:09:17 AM(UTC)
