The washing machine works fine up to the rinse cylce then stops. So it doesn't rinse or do the last spin cycle.
Hi Kevin
Since your machine goes through a complete cycle (fill, agitate, drain, spin) in the wash cycle it would seem that there is nothing mechanically wrong, which suggests the timer is your problem.
Try replacing it and see if that does not solve your problem.
Good luck, let us know what you do and what happens.
