cabellabbott
#1 Posted : Monday, December 19, 2011 4:47:23 PM(UTC)
cabellabbott
My washer is working properly. At first I noticed that the clothes were very wet after being washed, and then the washer just stopped spinning. We tried changing the drain pump, and that didn't help. Next, we tried changing the control panel, and that didn't help. Finally, we changed the door lock, and the washer worked perfectly without any clothes in it. However, as soon as I put a load of laundry in it, it filled with water, turned several times to begin washing, and just stopped. Any ideas about what might be wrong?
ApplianceJunk
#2 Posted : Monday, December 19, 2011 7:20:56 PM(UTC)
ApplianceJunk
Bad connection on one of the wire harness plugs. Unplug them one by one, inspect and plug them back in.
