My gas dryer is functional but will not heat up. I want to access and test ignitor. It looks like the only way to do this is through the front panel but I'm not sure what procedure is to remove it. There aren't any screws and I don't want to break any pins. Where do I start? I removed lint assembly. I see two metal clips on the bottom of dryer.:confused:
