m2s
#1 Posted : Friday, June 26, 2009 8:27:40 AM(UTC)
m2s
The igniter heats up and ignites the gas. It stays lit for about 4 minutes, the gas goes off. When the igniter heats up the second time it does not ignite the gas. What part do I need? Thanks for your help.
#2 Posted : Friday, June 26, 2009 1:20:16 PM(UTC)
Most likely the problem are a bad gas valve coils (#10 & #11 on the diagram)
- The part number for the coil kit is AP3094251
Here are the breakdown diagrams and Replacement parts for AMANA AG5419 | AppliancePartsPros.com
m2s
#3 Posted : Friday, July 3, 2009 8:54:06 AM(UTC)
m2s
Got the part and it works great, thanks so very much.
#4 Posted : Friday, July 3, 2009 1:13:49 PM(UTC)
Glad to hear you are back in business. Thank you for your feed back.
