Ice maker works but will not dispense ice or water. I replaced the computer board which was burned up from a cracked water line. The touch pad is lit up on the cube selection , when pressed nothing comes out, and you can not change the selection to crushed ice or to water it is stuck on cube. I dont know what to try next ?:confused:
