I had my kitchen redone about a year and a half ago all worked fine,about 6 months ago the oven started tripping breaker(micro worked fine). There is a 30A with 10gage to oven (which ge said was fine) Replaced breaker and I have 121v out of each leg of breaker. when I hooked up the oven it tripped and now the breaker will not even stay set. I disconnect the oven and breaker stays set,Am I to assume the problem is in the oven?
Thanks in advance
