jonlim1208
#1 Posted : Wednesday, June 24, 2009 7:53:30 PM(UTC)
jonlim1208
I Started the washer with Medium water level. But noticed that the water was about to overflow (up to the top). So I stopped the machine. removed the water from the tub using a small bucket. Then I shut the lid, and switched it on(start)...and after a while noticed a strange sound. The washer had No water. I can see it agitate without water.
Now when I get it start again from the start position washer automaticaly start to agitate with NO water...(seems like washer does not even allow the time for the water to fill in) just start to agitate right away..
What do I need to check? And from reading your posts it sounds like water level switch.. What and how do I fix this??:confused:
applianceman
#2 Posted : Thursday, June 25, 2009 9:28:28 AM(UTC)
applianceman
From what you have said, the water level switch is bad. Clothes Washer Repair Guide
