Runs, works, but has a low humming vibration. Took out a wad of lint from fan. Anything else to look at while it's open?
Here are your parts Replacement parts for FRIGIDAIRE GSE746RFS3 | AppliancePartsPros.comSounds like you may have found the cause. Give the blower a spin to see if it now rotates without a wobble. Check the belt, front drum support and the idler wheel. Check the rear center mount drum bearing for wear, clean out the old grease and re-grease it with a high temp grease Might as well clean and check your vent system while you are at it. |
THIS FORUM IS DEAD!!!!!!! |
