lou agathos
#1 Posted : Wednesday, June 24, 2009 8:00:10 AM(UTC)
lou agathos
The tub won't spin. The machine will cycle manually and the motor works fine. The drive coupling from the motor has been worn out, torn out and the remainder of it was lying on the floor under the washer. I need a new drive coupling which I will order, but I also need to know the procedure for changing it out. Please help. Thank you. Lou Agathos
applianceman
#2 Posted : Wednesday, June 24, 2009 8:06:50 AM(UTC)
applianceman
This page should help you with this Whirlpool Washer Disassembly Guide
