allenwva
#1 Posted : Tuesday, December 13, 2011 7:06:50 AM(UTC)
allenwva
I have a Maytag dishwasher. model # MDB7650AWW. Tried to use dishwasher this morning I hit the start button. It started a put some water in. It then buzzed (sounded like it came from the top) and then turned itself off. Opened up the door there is water standing in the bottom. tried to restart. would not start, just makes a buzzing sound 4 times and then turns off. can you tell me what the problem might be?
magician59
#2 Posted : Tuesday, December 13, 2011 7:16:27 AM(UTC)
magician59
The first thing I would check is the power connection under the machine. Look to see if one of the wire connections came loose. Especially look for a loose ground or neutral.
ApplianceJunk
#3 Posted : Tuesday, December 13, 2011 7:18:32 AM(UTC)
ApplianceJunk
Could be a bad motor tripping out on the build in overload or something stuck inside it that is keeping the motor from turning.
I would also remove the access panel at the bottom of the dishwasher and look around under it, does it look like it's been seeping any water on the motor or connections?
Here is the service manual for your model dishwasher, you may find it helpful.
http://appliancejunk.com...ownloads;sa=view;down=83
Frigidaire dishwasher code A (Dishwasher Repair)
by Evandtam 6/27/2024 5:11:41 PM(UTC)
Fisher Paykel Drawer Dishwasher will not Lock (Dishwasher Repair)
by thompsdw 6/17/2024 7:34:54 AM(UTC)
Dishwasher won't work. (Dishwasher Repair)
by Guest 5/23/2024 6:32:18 PM(UTC)
High-pitched noise with LG dishwasher (Dishwasher Repair)
by Guest 5/17/2024 5:13:53 AM(UTC)
Cafe Dishwasher little to no heat, not cleaning dishes well. (Dishwasher Repair)
by Jtaylor20 5/16/2024 10:15:38 AM(UTC)
Bosch Dishwasher dirty water in filter " hole" (Dishwasher Repair)
by Guest 5/14/2024 9:47:25 AM(UTC)
Bosch dishwasher SHVM78Z53N/01 (Dishwasher Repair)
by Guest 5/8/2024 8:58:29 PM(UTC)
Continuity TEst Samsung p/n 33299012 Dishwasher Water Inlet Valve. (Dishwasher Repair)
by cprodave 4/27/2024 6:55:56 PM(UTC)
Samsung DMT400RHS Dishwasher Over Level Water Error. (Dishwasher Repair)
by cprodave 4/27/2024 6:24:56 PM(UTC)
Samsung Dishwasher Water Inlet Valve--how to Test? (Dishwasher Repair)
by cprodave 4/27/2024 6:18:51 PM(UTC)
Kitchen aid dishwasher bottom leaking (Dishwasher Repair)
by Guest 4/21/2024 10:31:25 AM(UTC)
Bosch Dishwasher SHE3ARF6UC/22 E15 Error (Dishwasher Repair)
by codyace 3/29/2024 11:51:41 AM(UTC)
GE dishwasher GDT695SSJ0SS middle arm not spinning (Dishwasher Repair)
by merrittjr 3/23/2024 10:51:00 AM(UTC)
Bosch Dishwasher Display Goes Out After Latching Door (Dishwasher Repair)
by Guest 3/11/2024 7:00:18 PM(UTC)
Kenmore 90 665 dishwasher noise from impellor (Dishwasher Repair)
by Guest 3/10/2024 12:30:08 PM(UTC)
