Does anyone have a tip on how to mount a condenser fan onto the motor shaft?
The old one was held onto the shaft by a spring that you cannot access with standard tools because it is under the the center of the fan blade body. I know that is hard to visualize unless you have seen it.
I have already broken the old fan trying to push it back onto the shaft and don't want to do the same thing to the new fan when it arrives.
