Jenn Air downdraft oven model # SVE47600WS display not working. Clock is now so dimmed you can't see it. oven works. What part fixes this.
Thank you. Will instructions be included with the purchase of the part? Is it relatively straightforward to install.
Quote:Will instructions be included with the purchase of the part? Not usually no. The only time instructions are usually included with appliance parts would be if there were changes necessary (eg. to the wiring, etc.) for the replacement and it would only describe those specific changes, not the whole repair job. The following service manual might help with the basic construction of the appliance: LINK > Electric Slide-in Chassis Range Service ManualQuote:Is it relatively straightforward to install. Once you have access to the original control, swapping the replacement shouldn't usually be difficult. JMO Dan O. www.Appliance411.com The Appliance Information Site=D~~~~~~
