sunshineb
#1 Posted : Sunday, December 11, 2011 9:56:10 AM(UTC)
sunshineb
Our Samsung Oven quit working. The stove top is working great. The broil looks like it is working, but never heats the oven. The bake will get up to 100 degrees (I'm using a thermometer to get temp). We also noticed it will immediately say it is at 400 degrees, but the oven isn't warm at all. The bake is flashing on the display and we will occassionally hear a clicking noise. This only happens when trying to use bake.
#2 Posted : Monday, December 12, 2011 5:20:06 AM(UTC)
Here are your parts includes a wiring diagram.
Replacement parts for Samsung RESF5330DT RANGE- S/C F/S ELE | AppliancePartsPros.com
Since the board is giving a false temperature reading I would check the oven sensor first.
Here is a good link, check out 7, 8, 20 and 21.
http://www.applianceaid.com/elecrange.html
You will notice that higher resistance equates to a higher temperature so also check that the connection is good.
