Burner comes on but shuts off withing a couple of minutes. It does not matter what dying mode is being used - high, low or dryness. The burner stays locked out for a considerable length of time and will not ignite in any drying mode position.
replace the coils on the gas valve. the secondary coil is not energizing. replace both coils. it is a cheap and easy fix. tom
