llchap
#1 Posted : Sunday, June 21, 2009 2:44:32 PM(UTC)
llchap
I need help locating the drain and suggestions on the best way to unclog it. Water is dripping into the bottom of the refrigerator compartment and I found a lot of ice buildup under the floor of the freezer compartment. A picture of what I'm looking for would be most helpful.
Thanks, Lee Chapman
woodchuckie
#2 Posted : Sunday, June 21, 2009 8:43:40 PM(UTC)
woodchuckie
Part 7 on diagram 6 is the heat shield drain pan combination. It's under the evaporator behind the back panel in the freezer.
Forcing bleach/water under pressure through it with a turkey baster usually clears it out and prevents mold etc. from stopping it up again.
