My freezer works OK it seems but the refrigerator is warm. Can it be the compressor? Fan? How can I check?
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's open. If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too. check defrost timer, defrost heater, defrost thermostat> Refrigerator Repair Guide: How To Fix a Refrigerator - ACME HOW TO.comIf the heater and thermostat are ok it’ll be the timer. Diagram 2 is your damper control parts. Part 12 is your timer. Replacement parts for ADMIRAL ATF2110DRA | AppliancePartsPros.com
