glendapeck
#1 Posted : 13 years ago
glendapeck
I have a 1 year old Kenmore dishwasher. The keypad is push button which lights up for each choice. At first I could not switch between and different wash cycles, it just stayed on pots & pans and I could push the start button and it would go thou the wash cycle. Then it just stopped, so I tested the thermal fuse and it was fine. Then I purchased the control board and changed it out...shut the door, restored power and the washing light was on and the dishwasher was making noise like it was draining. It did this for a couple of minuets then stopped. I went to push the wash button and nothing happened...:confused:
Truman99
#2 Posted : 13 years ago
Truman99
I'm fixing mine now. Squeeze the door latch 5-10 times, Does it spring back? My unit started working after I did this, same symptoms as yours. I believe the door latch switch is going bad as it is on my unit. I just ordered one
Control Panel on my Maytag Dishwasher is dead (Dishwasher Repair)
by mauryb 14 years ago
kenmore dishwasher is dead (Dishwasher Repair)
by partyguy3800 16 years ago
by Glenvan 16 years ago
by rchiga 18 years ago
