Jake53
#1 Posted : Sunday, June 21, 2009 6:00:07 AM(UTC)
Jake53
Maytag dryer no longer heats up. Can you tell me the trouble shooting procedure for jumping components (ie timer, etc) to find the problem source.
I have the wiring schematic.
thanks,
jake53
sidfink43
#2 Posted : Wednesday, June 24, 2009 3:51:05 PM(UTC)
sidfink43
Hi Jake
Your model number does not come up, can you check it.
I am assuming your dryer runs but does not produce any heat. The initial checks are for continuity to the thermal fuse/thermostats and if electric, see if 240 v current is getting to the machine and that the heating element has not shorted.
If gas, look at some of the other posts on this site for troubleshooting gas dryers that do not heat.
Good luck, let us know if you need more help.
