I Checked And The Faucets Are On, Checked The Inlet Screens, Hoses Are Not Kinked, And Water Hoses Are Not Frozen. What Could Be The Problem?
Could find no info on the given Model Number. Could it be that it is a GHW9150PW0 |
THIS FORUM IS DEAD!!!!!!! |
Thank You ,yes It Is Ghw9150pw0
Originally Posted by: denman ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Could find no info on the given Model Number. Could it be that it is a GHW9150PW0 YES IT IS GHW9150WP
Originally Posted by: denman ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Thank you so much, I will check the hoses better, and check out the teck sheet. THANK YOU AGAIN.:)
Originally Posted by: meeksj ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Thank you so much, I will check the hoses better, and check out the teck sheet. THANK YOU AGAIN.:) It's not that my washer isn't geting enough water, its getting to much water then it beeps and flashes FH then it stops and drains all the water out. Is there a part that lets the washer know when to shut the water off. I even push pause button and then push the start button again and it dose the same thing over again.
Sounds like either the water level switch or the flow meter |
Originally Posted by: denman ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Sounds like either the water level switch or the flow meter THANK YOU SO MUCH.
Originally Posted by: denman ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Sounds like either the water level switch or the flow meter Agreed :):)
