Chris10
#1 Posted : Saturday, June 20, 2009 1:13:12 PM(UTC)
Chris10
Hi, I have a GE Arctica side by side with water in the door. When I install a filter (have tried two) little to no water comes from the door. When I remove the filter and put the Filter Bypass in the water works fine. I really want to have the filter in place if possible, any ideas will be greatly appreciated!
#2 Posted : Saturday, June 20, 2009 4:54:57 PM(UTC)
What is the part number of the filter you tried to install?
Chris10
#3 Posted : Sunday, June 21, 2009 3:31:55 AM(UTC)
Chris10
Hi Gene, thanks for reading this, I used the GE MWF Water Filter that twists in. When the filter is empty and first installed I can hear it fill fast and then the water slows to a drip at the door in about five seconds. The filter(s) are from Home Depot. Thanks again,
Chris
