pjkinney
#1 Posted : 17 years ago
pjkinney
Waking up this morning, we find that the numbers 3 and 4 do not respond on our touchpad. The lower oven will also not start when the "start" button is pressed. Is there a code which we can key in which will set the board to somekind of default condition? Thanks
#2 Posted : 17 years ago
Most likely the problem with you microwave/oven combo is a bad key pad.
In order to help you with the right part number I need the color of the control panel and the end (one or two more digits) of the model number.
Happy Holidays!
