I have a Whirpool LER7620KQ1 that won't start. It has power to it. I also replaced the start switch thinking that was it but no luck. I can turn the timer on and hear it clicking like normal, hit the start button, nothing. Also, turning the timer all the way to zero as well as opening the door releases the start switch so I am pretty sure that the door latch is working as well. Tub moves as should and the belt appears in good shape. Any ideas what my problem might be? I am hoping to fix it myself to keep the cost low. THanks in advance for the help.
Thakns for the quick response. I just contacted a local vendor and bought a fuse. Will give it a try when I get home.
Your welcome, let's us know if that fixes it.
