When you push the button on the control panel, the display flickers while showing the time left. The timer does not countdown, but it sounds like the washer tries to start up and then clicks and then nothing. For instance, when you select auto clean, it will flicker 9 minutes on the display, sometimes it will fill. When it comes time to drain, a hum, then a click. timer stays put at 93 minutes. No motor sounds, no hum, nothing after the click. Any ideas what's up?
any ideas? i've got dishwater hands.
