We had a storm last night while we were out and our gas range was beeping a F5, I tried resetting the clock and would still go back to beeping the code. The oven turns on and everything works fine. Your online support has told me the manufactuer no longer makes the replacement part for the clock. We can't find the owners manual to maybe reset it somehow. Help!
F5 on that model is suppose to indicate a failed electronic control. And yes the control part # 5303269513 (AP2140445) does look to have been discontinued and is no longer available. If needed, you may be able to find a company to repair the original electronic control by searching the Internet. JFYI Dan O. www.Appliance411.com The Appliance Information Site=D~~~~~~
Thank you Dan for this information. I did end up plugging the stove back in around dinner time and so far it has not beeped the code, everything works and it's fine. Do you think it had something to do with the storm or is it just starting to fail on us?
Quote:Do you think it had something to do with the storm or is it just starting to fail on us? It's possible. Power fluctuations cause all sorts of problem with electronic controls. :rolleyes: Good luck! Dan O. www.Appliance411.com The Appliance Information Site=D~~~~~~
