can anyone I will appreciate help with troubleshooting my clothes dryer problem. The heat is slow in turning on and then after being on just a few minutes (or seconds), the heat goes off and I hear a rattling sound in the back of the dryer. I then turn the heat setting to air fluff/no heat. If I wait about 10 minutes, I can return the heat setting to ON and it will re-heat for a few more seconds (or minutes) before the heat cuts-off again. This is the only way I can dry my clothes now. I need help in narrowing down my choices of whixh part(s) to replace. And, I would like to do the job myself, if I can--eventhough this will be my first time working on a dryer. I would be very grateful if someone could get back with me no later than Monday morning (Dec 24th.) Blessings on you and yours.
---R. McNutt
Sounds like you have a bad blower in the dryer and the dryer is not even venting air, just check.
burner will not stay on Igniter keeps comeing on but will not light half the time replaced thermostat flame sensor igniter booster and holding coil
