need help on getting the new belt on.. How do you do it?? help
I believe there is no adjustment for this, it just has to be put around the tub pulley and motor. If the original belt worked it's way off, you probably have bad tub bearings, just check by manually turning the spin basket.
belt help
(Dryer Repair)
by Dryermang
1/2/2009 8:51:22 PM(UTC)
